Samwise Gamgee
I have anchor rods that are 3/4" and 1" diameter. If plate washers are being used for base plates, the hole diameters for platers need to be per AISC table 14-2 or Design Guide.
What is the diameter of the hole in the plater washer ? We specify use AISC standard washers, are the hole sizes in them just 1/16 greater than anchor rod diameter ?
