tona2008
- Apr 11, 2008
- 18
Hi everyone,
I was given the task of automating an oil heated press operation. The hot press needs two PID loops one to control the temperature and one to control the pressure. I have programmed the SLC 5/03 PLC before but only to control discrete outputs to open/close valves, alarms etc. Never dealt with analog signals. I need some guidance on which would be the combo PLC/HMI combo to use that will be the easiest to program and configure. Are there any PID modules on any PLC manufacturer that I can use to control the temperature and pressure? Can they be interphased to an HMI so that I can start the loops from an HMI screen? Does it have to be a PLC?
Any help will be appreciated.
Thanks,
Thanks,
