Please, explain me how to save mo
olga
Industrial
May 28, 2002
12
Please, explain me how to save models created in MD4 in ACIS format. Every time when I try to save my model in ACIS format, MD tells me: " No solids, regions or ACIS bodies selected", but I believe my model crated in Mechanical Desktop is solid.
Thank you,
Olga
U R asking to make a file in SAT format (filename.sat)
The command AMSTLOUT works for all true MDT parametric solids.
Angelo
To save a MDT part or assembly in ACIS format use the "AMACISOUT" command. To save an AutoCAD solid in ACIS, use the "ACISOUT" command.
Dear, Ronm
Thank you very much for your help, it works.
Olga
