Please what's the exactly meaning in the Annotaion note of drawing?
Runsong Lin
3
Hi everybody,
As below image, here is a typical steel design drawing. But some annotation notes weren't be understood clearly. In fact, I hope to know what is exactlty meaning about "9.5Z12-31.8 15/16PE(D.N.)" ? Could you please give some advice or recommend some relative specification? Thank you in advance!
Please don't double post.
The 9.5 is the depth, the "Z" is the shape. The 12 is gauge of steel used. Not sure on the rest though.
9.5Z12 is a "Z" shape 9 1/2" tall made from 12 gauge material
try this URL for a cut sheet
31.8 15/16 I think is 31'-8 15/16" long
The abbriviations are more of a mystery but a girt manufacturer might know or they may be clarified on the drawing
I'm sure others in this forum will help much more than I
  • American_girts.pdf
Thank you and Get it!
Is it common to dimension the building in millimeters and components in inches in your area? The x-bracing also appears to be in inches.
