Pleated filters versus socks
rocketscientist
Chemical
Aug 19, 2000
86
I generally have had the best experience with sock filters proceeded by a duplex strainer. A sock can get down to 0.5 micron and a strainer can go to 37 microns. What do you think? Which is better, sock or cartridge?
If there were one "best" filter there would be no other types available.
I generally prefer sock filters where I can use them. Pleated filters generally suffer bypass and can't be recovered. Socks can be re-used.
Bag filters are cheap and are generally used by people that don't know any better. The bags are typical rated as "nominal" micron size, meaning that about 65% of the "nominal" micron sized particles are retained. Of course, you can also specify an absolute filter, but then you will suffer with low capacity.
Cartridge filters are more expensive, but will allow higher capacity, more predictable performance, and longer filter runs because of in-depth filtration.
Both bag filters and cartridge filters are only suitable for low solids polishing applications. Otherwise, the performance will suffer.
