engr2GW
Petroleum
- Nov 7, 2010
- 308
for liquid gathering pipe (ASME B31.4), API 5L materials are listed, but there was a foot note that recommends the PLS 2 types. apart from a little variation in the chemistry (which I don't understand quite well).
My questions are:
1. is PLS 2 grade B?
2. I believe that PLS 2 is group 1 and P 1(with respect to welding)?
3. a welding procedure qualified for A106 grade B and API 5L X-42, X-46, and X-52, can it be used to also weld the PLS 2 designation (X-42N, X-46N, and X-52N)?
4. hardness testing is one of the ways that can be used to NACE qualify a welding procedure by controlling hardness, is the hardness survey was done on and qualifies A106 grade B and API 5L X-42, X-46, and X-52, can it also be used for the PLS 2 designation (X-42N, X-46N, and X-52N)?
5. is chemistry the only difference between PLS 1 AND 2? because most of the mechanical properties are similar/same.
thanks for your response.
As much as possible, do it right the first time...
My questions are:
