Pls Help - Entropy production in compressors
aliserose
Chemical
Dec 5, 2007
Typically, the exit pressure from a stage is ~ 2 times the entering pressure. A mol of hydrogen at 1 bar and 300 K is to be compressed to 300 bar and 300 K. We can cool the hydrogen to 300 K between stages using heat exchange with ambient air.
My question is How do we calculate the entropy production per mole of gas compressed in a continuous process as a function of the number of compression stages employed for the whole range, 1 stage to an infinite number of stages, using enthalpy pressure diagram.
We can assume a stage efficiency of 0.5 and ignore entropy recovery during heat exchange. Hydrogen can be assumed to be an ideal gas.
Many thanks,
Alise
