Pneumatic Timer
mapsbam
5
I am looking for a simple and inexpensive adjustable timer for a pneumatic application. We have carts with meter mixer pumps that are pneumaticly powered. I want to install timers that can be set for a certain amount of time(roughly 5-13 minutes)so that the pump will shut off when the time expires. Any help is appreciated. Thanks.
Good morning,
Does your application have to be pnuematic can you electrical install solenoids to the air source that are controled by timing circuit?
2571
Check with Festo. They have pneumatic timers.
2571: The valve can be electrically powered, but the valve itself is to cut off the air supply.
quark: Thanks, I'll try Festo.
