mula1
- Apr 16, 2019
- 1
Hello all,
I have a question which I need a bit of help envisioning.
I have a heavy machine with 4 legs that i need to place on the floor, but I don't believe the floor will be able to withstand the point loads generated by each leg - The floor is suspended.
To solve this I wish to place a steel plate under the machine to spread the point loads of the machine legs across the floor. The plate will be fully supported by the floor i.e. there are no gaps in the floor.
What I need help with is how the steel plate will distribute the point loads, I'm pretty sure I will have diminishing circular stress spread from each leg? There may be overlapping stresses generated by each leg.
If I have maximum load capability of the floor, how can I convert 4x point loads on the top of the steel plate to work out the force exerted by the base of the plate to the floor?
I believe these calculations will help me find a suitable thickness of SS plate?
I have also thought about using 2x SS planks instead of a plate but I wish to start with looking at a plate first.
Many thanks for any help.
