It depends on time of exposure and time to dry out between exposures, and the temperature, and a little on the grade of polypropylene used, and even a little on the moulding conditions, but the last two points are probably so insignificant as to be unmeasurable.
I don't have any hard data available to me now, but the suppliers of the polypropylene moulding compounds should be able to supply actual measured data.
You could calibrate your beaker once a week or so by comparing to a glass beaker, or by weighing the indicated volume. You might need to test the SG with a hydrometer, to correct the expected to variations in the Jet Oil 2. I am not familiar with the actual spec of Jet Oil, but I am presuming it is mainly allephthatic (sorry, I have a brain fade and forget how to spell it, and it's not in my spell checker) hydrocarbons with some aromatics as well.
Alternatives are metals like stainless steel or aluminium if high levels of accuracy are not required, or glass if accuracy is required, but durability is not so important
pat pprimmer@acay.com.au
