thread330-257321
I am having a similar problem with porosity in CA6NM on impellers and casings. Porosity appears on sections less than 0.5" and naturally in the risers.
Melt process is air induction furnace with Ar plug. Charge includes revert, 1010, ferrochrome (0.05% N according to the vendor) and electrolytic nickel. I've maxed out Ni, minimized Cr. Using Mn and FeSi for initial deoxidation in furnace and Al and Graphidox (54%Si, 10% Ti, 6% Ca) in final procedure before pouring to laddle.
Last two times we poured CA6NM were rainy overcast days with high humidity, both times castings were scrapped. We've had issues in the past but I would have to look up weather on those days to say anything definitive about moisture. However, the porosity observed did appear on the drag side possibly indicating off gassing from the no bake phenolic mold. I've sent samples out to confirm N content, should get them back in a week.
Can anyone recommend laddle deoxidation procedure? I'm curious about using either more Al, or trying FeTi, or Zirconium (read that 0.1% should be enough). If Al, can anyone specify max to avoid AlN embrittlement? Any experience would be helpful.
lkrzyzan
lkrzyzan
