StrEng007
- Aug 22, 2014
- 543
Are there any basic rules that apply to the applicability of the portal frame method?
For instance:
1. Column height to beam length ratio should be approximately 1.0?
2. Column to beam inertia should be equivalent and must be of the same elastic modulus?
3. Results from a portal frame method are expected to be 20% higher than FEA or moment distribution method?
For instance:
