lameparime
I’m inspecting a call out identical to figure 8-38 on the attached image. The issue is that my mobile CMM is only capable of checking position of a 2D slot feature. There is not a single mention online of inspecting the position of a slot along the whole length of a hole. For circular holes you can inspect the hole as a cylinder and check it with cylindrical position tolerance.
I’m considering either:
1. Checking position of a 2D slot at the top and bottom of a through hole separately
2. Taking points at various depths so that the 2D slot is average of the whole length
3. Taking two planes on opposite side walls of the hole (since I’m checking position in one direction anyway) and somehow checking if their mid plane is within position tolerance
4. Taking slot at each end, making a line from their midpoints and checking if that line is within the tolerance
The concern is to find out if the hole is in tolerance at all depths
