I am designing a system and I need to balance the load across a 208 3 phase input. I am balancing a bunch of equipment, each having a different power factor. When trying to balance the power factors on each phase, should I just average the PF or is it more complicated than that? Balancing just the loads is easy, but I think the PF needs to be close on each leg also. The answer is probably simple and I will most likely kick myself when I hear it, but I am still new to all this (recently graduated). Thanks for the help ahead of time.
