Dears All:
I´m designing one system in Low voltage, now I have one doubt. I have calculated the KVAr´s to increase the F.P. from 0.86 to 0.9 by local regulation, however, I have considered the load in operation but i not sure if that is correct because I think the installed load shall be considered, please send me your opinion.
Obviously when the system be started i will know the Power Factor but now i´m in stage of design.
Thank you.
Thank you.
