Mar 6, 2006 #1 22574 Electrical Dec 9, 2002 28 0 0 PH I am looking for a complete Power Transformer testing instruments.. please specify what brand. Eduardo
Mar 6, 2006 #2 amps21 Electrical Jan 10, 2006 70 0 0 US Is this inhouse testing or field testing ? Routine testing or predictive maintenance testing ? I mean, please specify. Upvote 0 Downvote
Mar 6, 2006 Thread starter #3 22574 Electrical Dec 9, 2002 28 0 0 PH This is for field Testing. If you can provide both routine and predictive I will appreciate it very much. Upvote 0 Downvote
Mar 7, 2006 #4 Zogzog Electrical Mar 7, 2006 1,579 0 0 US You will need a megger (Voltage depends on the transformer), a TTR, a winding resistance test test, a power factor test set, a microohmeter and oil sampling equipment(if oil filled). You will probally spend close to $100,000 on the equipment (new). Upvote 0 Downvote
Mar 7, 2006 #5 Kyle2022 Electrical Jan 26, 2005 20 0 0 US Zogzog is right on with his equipment suggestions. You mentioned that you are looking for specific brands. We use the following: Megger: AVO (as he said voltage depends on transformer) TTR: Biddle Winding Resistance: AVO Power Factor: Doble M4000 Microohmeter: Biddle Upvote 0 Downvote
Mar 7, 2006 Thread starter #6 22574 Electrical Dec 9, 2002 28 0 0 PH Thank you very much from you replies.. If you know other Brands, just please send it to me. Upvote 0 Downvote
Mar 7, 2006 #7 amps21 Electrical Jan 10, 2006 70 0 0 US A quick point to remember: Make sure the test instruments u get use test methods and specs. etc per your relevent country standard. Also get the instruments with a cal. sticker. Google your test requirement. There are expensive test sets and economical ones too. Like AEMC, Vanguard. Visit their websites Upvote 0 Downvote
