Powercopy with assemblys
jmuriarte
Automotive
Oct 28, 2005
36
0
0
ES
Hello again.
First, thank you very much Solid7.
I need to know if it is possible to create a powercopy with assemblies. For example create a powercopy to make a hole in a part and put a screw (DIN912).
Powercopy is used for CATPart's, this is a multi step operation -
1) the powercopy for the CATPart
2) Assembly design - could use a catalog to insert the screw
3) If you want the screw constrained to hole use Smart move, if not you could align them using snap.
Eventually a script could be written.
What license scheme do you have?
Derek
Hi
Is it possible using macros to transfer holes from one cat part to another in assembly in catia V5?
Here is my requirement:
There is one assembly say die show assy. This assembly contains die shoe.CATPart and WearPlate.CATPart.
Wearplate is assembled on shoe.
I need to transfer holes on wearplate to die shoe.
Currently I have to do this activity manually.
For large assembly this takes a lot of time.
