- Moderator
- #1
The power stroke, specifically the 6.4L and the "Son of Powerstroke" the Maxxforce 7 have a reputation for early failure.
Past 40,000 to 60,000 miles you may be on borrowed time.
The failure progression as service manager explained it to me is
First;
The high pressure pump wears and puts metal particles in the common rail.
Second;
The particles jam the valves open or partly open in the injectors.
Third;
Over-fueling melts pistons, overheats a cylinder, leads to cylinder washing and accelerated cylinder wear or some combination of the above.
If you are lucky, one injector will jam so far open that the common rail cannot build sufficient pressure and the engine will not start.
Replace injectors and fuel pump and drain the fuel tank and flush the fuel lines. Can run to $20,000.
Question #1 Is the original problem a bad pump design, or a bad injector design? Will other manufacturers injectors pass the microscopic metal particles that kill a Powerstroke/Maxxforce?
Question #2 Is there any remedy other than a different make engine?.
(There is rumoured to be a drop in replacement from Cummins. Cost $44,000 CDN, plus labour and taxes.)
From rumour to anecdote;
A mechanic friend told about servicing a fleet of about 500 trucks on a large pipeline project several years ago.
Admittedly the trucks were somewhat abused; Cold weather starts at minus 30, idling for days at a time at minus 30 to avoid starting issues.
Of the 500 trucks about 120 were Powerstrokes.
Out of 120 Powerstrokes about 90 suffered early engine failure. Most failed at or under about 60,000 km or 40,000 miles.
One truck lost the engine the second time on the way back from the dealers to the jobsite.
The class action suits are ramping up.
Bill
"Why not the best?"
Jimmy Carter
First;
Second;
Third;
Bill
"Why not the best?"
Jimmy Carter
