JStructsteel
- Aug 22, 2002
- 1,438
Got some small precast pieces (lintels, 'cast stone' that are integrated with the brick in a building. Some are brick above and below, so just supported by masonry mortar, like any other brick. Some of the bigger pieces are on steel angles. Would you give any value to the mortar between the precast and steel, or would you provide a mechanical anchor?
