I have an assembly which is essentially a spherical ball located in a cylinderical pipe.
I am after a formula that can be used to calculate the pressure drop across the ball for a given fluid flow rate in the pipe.
There is a small clearance between the ball outside diameter and the pipe internal diameter i.e. all the fluid flows through an annular ring around the ball OD.
The fluid flowing through the pipe is oil.
Any pointers / sources of information that you can provide would be gratefully appreciated.
Thanks in advance,
Brian
Thanks in advance,
Brian
