Pressure drop through nozzle 3
mjpetrag
224
If I have a system like this...
1" 0 psig
3" 80 GPM 60 psig>-----------|----------> ? psig, 3"
How do I find the pressure drop across the tee if the 1" line is dumping water to atmospheric pressure. Basically I need to find an equation that finds the pressure in the right hand pipe taking into account a loss of mass flow. I couldn't find one anywhere.
-Mike
i checked with 2 different methods and got around 56 psig both times...my e/D is around .0024 for stainless steel with a friction factor of .0268
-Mike
Yes, you are right. It was a bug in the software I used. Thanks!
Good luck,
Latexman
