andymagpie
hello, i am very new to pro mechanica. I am trying to apply a uniform pressure of about 5 psi to a model. the model is basically a sheet metal plate about 1m^2 that is constrained at longitudenal ribs (x5) equally spaced. The plate is about 2mm thick and made from nickel cobalt. when i run a static analysis the von mises stress is much larger than anticipated. I am applying 34kPa (5 psi) and the max stress is 500 Mpa?
I would really appreciate some help in this matter.
