escapadro
- Oct 4, 2017
- 13
Hi gentlemen, I'm new to this forum!
I have a question regarding a PRV. There is an existing line of pressurised air that is planned to be divided at one user point into two. One branch will be reducing pressure to 2, and another should stay at 6. Now, is there a PRV, that will be pre-set to reduce the bar from 6 to 2 and lock, but also have a possibility to be manually closed from 2 to 0? At the end of the day, operator should be able to come up and close the valve, shutting down the process.
Maybe there is some sort of a PICV that could do that?
Thanks in advance!
If pictures of the process are needed, I may be able to provide them for further help.
Cheers!
Thanks in advance!
Cheers!
