Asisraja D
- Jan 3, 2024
- 175
Hi
It is room temperature fluid
Centrifugal pump
Pump head is 25 meter (2.5 bar)
Cooling tower pump
Header size is 3"
Branch size is 1.5"
We are getting 3.5 bar pressure at reactor manifold?
Is it possible to get 3.5 bar pressure at 2.5 bar head centrifugal pump ?
Fluid temp is room temperature (25 to 32 deg.c)
Constant density (998 kg/cm2 to 1000 kg/cm2)
Flow rate is 45 m3/hr
Is it possible?
Centrifugal pump
Cooling tower pump
Header size is 3"
Branch size is 1.5"
Is it possible?
