subsearobot
- Jan 19, 2007
- 217
Hello folks,
Any idea of an approximation of the relationship between pressure and viscosity in a hydraulic oil? The oil that I am using is a synthetic.
System will be operating at about 12,000 psi on the pressure side (with the "reservoir" at ~9000psi), and want an idea of the approximate delta in the stated viscosity, which will be either 07 or 15 cst. I have contacted the Mfr, but the information has not been forthcoming- they may not have tested to that pressure, and are hesitant to give estimates.
I realize that temperature and oil chemistry have a strong effect here. I'm just looking for a rough order of magnitude- will the visc double, or just increase by 10% due to pressure?
thanks, as always, for your thoughtful input here.
