Andreaschar
- Dec 5, 2013
- 9
I am trying to simulate a wire that is pretensioned and clamped on a ring and then loaded transversely.
I apply a negative temperature on the wire (I modelled the wire alone with axial loading and found the appropriate temperature) but the results are way off the expected results. I found that the temperature does not have any effect when the transverse load is applied but when I run the simulation without a transverse load the wire shrinks.
I am running a linear solution, apply initial temperature and temperature load to all components (20 to everything except wire, -150 for wire)
Anybody has any idea why is that?
Thank you
Thank you
