PRINTING WITH NX 12 SIEMENS SCALE 1 TO 1 2
JINKA
Automotive
Aug 16, 2021
1
HI TEAM
FIRST TIME HERE
AFTER READING HOW TO PRINT USING NX 12 SIEMENS AT A SCALE OF 1 TO 1 WITHOUT SUCCESS FROM THE FORUM, I WOULD LIKE TO SHARE WHAT I FOUND.
TO PRINT FROM NX12 SIEMENS AT SCALE 1 TO 1 TO A PRINTER
OPEN THE SKETCH YOU WANT TO PRINT
SELECT FILE - EXPORT - PDF.
IN THE PDF SCREEN YOU WILL SEE A SIZE BUTTON, CHANGE THE SIZE TO READ FULL SCALE.
PRESS OK.
ONCE COMPLETED OPEN YOUR PDF FILE YOU JUST CREATED.
GO TO FILE - PRINT.
OPEN THE POSTER BUTTON AND SET SCALE AT 100%
YOUR SCREEN MAY HAVE MANY PAGES WITH A SMALL SKETCH IN THE MIDDLE OF IT.
PRESS PRINT AND RECYCLE YOUR MANY UNUSED SHEETS OF PAPER.
AT THIS STAGE I HAVE NOT BEEN ABLE TO ENLARGE THE SKETCH AND NOT WASTE PAPER.
YOUR PRINT WILL BE THE EXACT SAME SIZE AS YOUR SKETCH DIMENSIONS MINUS ANY PRINTER ERRORS WHICH ARE NORMALLY MINIMAL
CHEERS JINKA
P.S THANKS TO THIS GREAT FORUM IT HELPS ME A LOT AND HAPPY TO BE ABLE TO CONTRIBUTE.
Your caps lock is broken. You'll never be able to make a 1:1 print until it is repaired.
If printing full scale is a normal thing with you then it is probably best to purchase a plotter instead of using a printer.
Jerry J.
UGV5-NX1961
