Hello, I have the following problem with the I-deas 10. I exported in IGES file a model and CATIA, but when I give the order to export appears a message that can not execute this function.
When I exported to IGES can not do that and instead see the following message: "Server IO is not enabled (To enable, disconnect
SDRC_OI_OFF). "
However when I want to export to CATIA I can not do it and the following message appears:
"The server Open I-DEAS unavailable.
To run this product, you should:
1.) Exit I-DEAS
2.) Typing "export SDRC_OI_ON = 1"
3.) Restart I-DEAS
NOTE: If this product often used, you can add
"Export SDRC_OI_ON = 1" file to your home. "
It seems clear how to solve this problem according to what I indicated I-deas, but that folders and files should I seek to modify these files?
In what ways have you done?
Thanks for the help.
Greetings.
SDRC_OI_OFF). "
1.) Exit I-DEAS
3.) Restart I-DEAS
Greetings.
