  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
Projecting a curve onto an unbended sheet metal part
AntoSilv
6
0
0
NL
Hello everyone,
I am currently trying to project a curve on an unbended metal sheet part. I am following the following steps:
1) Design the metal sheet using SB Contour flange
2) Unbend the geometry
3) Projecting the sketch on the unbended surface
4) Bending again
The problem is that I am not able to have the sketch following the bending path. I believe I understand why this approach doesn't work since for NX there is no previous position for the projected curve, nevertheless, I cannot find a proper way of solving this problem.
Please check the attached image for easy understanding of what I am trying to do.
Thank you for your time in advance.
 https://files.engineering.com/getfile.aspx?folder=3fd888d8-8ebb-4299-a9c5-46d8423b3d50&file=Bending.png
Hi.
In this case I Will suggest simple divide the face straight aften placing Your sketch....
Use sketch Curves AS argument when applying divide feature on surface....
Hi Iklo,
Thank you for your feedback.
If I understood correctly your instructions, I still cannot rebend the face after dividing it on the flat surface using the curves:
Hi @AntoSilv
What is your end goal, why do you need the curve on the bent part? I ask becuase NX Sheet Metal supports additional curves on Unbend but not on Rebend.
If you need the curve for a cutout, then use Normal cutout on the flat form and rebend will transition the cutout.
Dave
Hi @deedub777,
This section is not for a cutout but to introduce some boundary conditions while doing FEM analysis to the component.
BR,
Anton
