PSV Inlet and Outlet Pressure Drop Calculation Question
Pavan Kumar
Chemical
Aug 27, 2019
404
Hi All,
I sized a PSV downstream of a Control Valve for its wide-open failure case and got a 6"Q8" PSV. The required relief rate is 254107 lb/hr with Oxygen as the fluid. The rated capacity of the PSV is 294,851 lb/hr with 10% overpressure. I tried to size the inlet/outlet lines to this PSV. The PSV inlet line is 2 ft long and the outlet pipe is 4 ft long with an elbow. The PSV is to be installed on the 6" line downstream of the control valve with option to move it to the 12" line.
My questions:
1. The PSV Inlet pressure drop should be calculated from the source of pressure, in this case from the control valve outlet flange or can I calculate it from the reducing inlet to PSV Inlet?.
My Calculations : (i) When I used 6" inlet line taking off 6" line the inlet pressure drop is 13 psi, which is 4.8% of the PSV Set pressure. I used AFT Arrow to do these calculations. If install the PSV on the 12" line and use 8" inlet with a 8"X6" reducer at the PSV inlet I still 4.8% inlet DP. Also this calculating the pressure drop from the TEE inlet and not the Control Valve outlet flange. Is there an option that you can suggest to reduce this DP to less than 3%. I can go with a Pilot Operated PSV option whose capacity is not reduced by the inlet line pressure losses. But that is an expensive option and I want to avoid it if possible as the body and trim will be made of Monel for Oxygen service.
2. For the outlet side, I used a 8"X12" expander, followed by 12" Sch 10 pipe that is 4 feet long and calculated the pressure drop to be 7.2% of the PSV Set pressure. The velocity is sonic across the PSV, becomes sub-sonic in the outlet line after the 8"X12" expander and reaches sonic at the pipe exit. I want to know if this acceptable. If I use 10" pipe then the pressure drop goes to 9.5% of set pressure. My AFT Arrow model screens shot for the 12" pipe option is shown below. You can see that even though I want 0 psig at the pipe exit, the model achieves only 0.42 psig. If I use 10" pipe then it reaches 6.7 psig (result pasted as well).
I also did calculations using my spreadsheet using isothermal compressible equation and I get 4% for the Inlet pressure drop and 22% for the outlet pressure drop. My excel calcs are close for the inlet side(4% vs. 4.8%) but there is large difference for the outlet side ( 22% vs. 7.2% ). My spreadsheet is attached also. I did this to cross-check AFT Arrow calcs. I wanted to understand why these are so different.
12" Outlet Pipe Option
10" Outlet Pipe Option:
Thanks and Regards,
Pavan Kumar
  • O2 Pressure Reducing Station - Calculations.xlsx
PSV inlet line : Standard practice would be to include the control valve exit into the inlet line dp calcs.
PSV exit line : Standard practice is to keep exit line velocity at <0.7Mach for brownfield applications, preferably <0.5Mach for greenfield, even if your exit line dp < 10% of PSV set pressure at process design relief flow.
Thanks George.
Pavan Kumar
If you install a 12" x 12" tee for the branch take-off then you will only have a 0.5 psi pressure drop in the connection since the tee branch connection pressure drop will be based on the velocity in 12" branch not 8" branch. Then with 12" x 8" reducer (12 ft equiv. L) and 2 feet of straight 6" pipe without need for reducer you will have less than 4.5 psi drop in this section for a total of 5.0 psi drop in inlet not counting the pressure drop due to increase in velocity from 12" to 6".
Also I am not getting 13 psi drop in inlet based on your configuration. I only get about a 6 psi drop with 12"x8" branch tee then 8" x 6" reducer plus 2 ft of 6" pipe. This is using 10 feet equivalent length of 12", 40 feet of 8" (for 12"x8" branch tee) and 10 feet of 6" pipe (8"x6" reducer plus 2 feet straight pipe). Maybe I have a mistake somewhere but I can't find it.
I was just looking at your inlet calculations. I think what you did wrong is that you included all pipe pressure drop under one calculation based on 6" line size. If you do this then the tee branch does give about 9 psi drop as you show. However, if you do a separate calculation for tee branch based on 8" size then the pressure drop through the tee is only about 3 psi. Then a do a separate calculation for the pressure drop through the reducer and 2.5 ft. of 6" pipe based on 6" pipe size and velocity.
Looking at your outlet calcs I see you made a mistake by including one 90 deg elbow in calculation of the 8" pipe segment - it is already accounted for as 12" in calc sheet 2. I also see some mistakes in your calcs for acoustic velocity value = (gkR(2/(k+1))T)^0.5 not what you show. Also for 12" the outlet pressure is not 14.7 psia as you assumed since velocity is sonic at exit so pressure will be above atmospheric at tip of pipe (and keep mach no greater than 0.8 for vent to atmos.). I will continue checking tomorrow if I have time.
Hi Snickster,
Due to changes in the PSV location I updated my PSV Sizing, PSV Inlet/Outlet Line Pressure Drop calculations and took care of your comments above. Kindy find the udpated file attached. Please let me know if you still see any mistakes. The new location is show below.
Thanks and Regards,
Pavan Kumar
I am looking over your calcs for 8" x 10" outlet line, have not got to the rest of calcs. One thing I have question about. You indicate that the exit pressure of the 10" vent pipe is 35.3 psig. How did you calculate this? I only get about 6.8 psig at 274,824 lb/hr at 92 deg F
From your original post you appeared to indicate that you were confused about how the Fathom model was getting 6.7 psig outlet pressure in the 10" and not atmospheric at the outlet, which appears to indicate you don't fully understand compressible fluid flow and what happens in a pipe when you reach sonic flow conditions. I suggest you read some technical discussion on compressible flow in piping. I will check if I have any references that goes into detailed explanation for you.
In short, when flow is subsonic in the vent pipe exits, the pressure at the inside tip of the pipe at the exit equals atmospheric pressure. As the flow increases the velocity also increases until the velocity reaches sonic, and at this time the pressure at the pipe tip inside the pipe exit is still atmospheric. If the flow rate (mass flow rate) increases beyond this point the velocity can't increase to accommodate the increase in flow since the limiting velocity in a pipe is sonic (this is what you need to understand and read up on). What happens is the velocity stays sonic and does not increase, but the pressure builds up inside the tip of the pipe exist to above atmospheric. This is because at a higher tip pressure at same sonic velocity of flow the mass flowrate is higher. This is how the higher mass flow rate is accommodated for. The pressure will build up to whatever is required inside the pipe tip exit as you keep increasing the mass flowrate above that value where sonic flow just starts. So the pipe exit can build up to 100 psig or more if required, as long as the total backpressure at the relief valve discharge does not reduce the relief rate of the relief valve. The total back pressure at the relief valve discharge is this pipe tip exit pressure plus the frictional pressure drop.
Other minor things I see on your 10" pipe calc:
Sonic velocity a' should equal = SQRT (gkRT) Where T is the temperature when sonic flow is reached = (2/(k+1))(To) Where To is stagnation temperature approx 92 F.
For long radius 1.5D elbow L/D=16 not 30, which is for a threaded small sharp bend.
There is no thru tee in the 10" section as you included in the fitting list
The table at the bottom lists the 10" outlet temperature as 33.33 deg C which is not correct. 33.33 deg C is the subsonc low velocity temperature of the fluid upstream of the relief valve. When the flow is sonic the sonic temperature is (2/(k+1))(T) = (2/2.4)(552 R) = 460 R = 0 deg F.
When I have time I will look over the rest. I did look at your relief valve set-up and think it will be better on the 12" header. As it is on the 6" CV discharge there is a high pressure drop in the 6" which will exceed the 3%. Also the relief valve orifice is extremely oversized so there will be big issues with valve chattering wanting to close as soon as it opens due to large pressure drop on inlet and discharge volume of flow so much higher than the input flow from the wide open control valve. If on 12" header there is enough volume in the header so that as the relief valve starts relieving the pressure in the 12" should be maintained without dropping too fast causing chattering of the relief valve and in my opinion you only have to do inlet pressure drop for the inlet piping of the relief valve and not back to the exit of the CV.
I found a resource technical discussion on the internet about sonic flow in piping coincidently prepared by AFT attached.
  • sonic-choking-in-compressed-systems-asme.pdf
Also I don't know if it is against any Code but I believe the exit velocity of a vent pipe should be kept to below 0.8 sonic but greater than 500 ft/sec (for dispersion of heavier than air gases) in accordance with typical client specifications. This will require upsizing your vent.
