Instnapp05
Industrial
- Mar 3, 2014
- 13
Hi All,
Per ASME SEC 1 code, set pressure tolerance for a PSV setting between 301 PSI to 1000 PSI is +/- 10 PSI.
For a Consolidated model# 2755B-2-X1-F1-WSC-RL PSV (Flange), do we need to follow ASME SEC 1 or SEC VIII code if same is being tested using air as the medium at our local valve repair shop?
It’s understood, if we are to follow SEC VIII during shop testing, the allowable tolerance would be much higher than SEC 1.
The valve repair shop is not equipped for testing safety valves with steam(non-ASME certified),however, when installed on site, they verify set pressure using the EVT equipment and make the necessary adjustments per ASME code SEC 1.
Is there a correlation calculation for shop testing of 2700 safety valves like 1900 PRVs?
Thank you kindly and appreciate your feedback.
