JStructsteel
- Aug 22, 2002
- 1,438
When attaching a PT ledger to a concrete wall for a deck, do you call out a seperation material like sill seal? or since its vertical nothing required?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Eng16080 said:I've never called out sill seal for this connection. Is the purposed to provide a moisture barrier? I almost think it would be better not to have it so that air can get in there and dry out the wood if it does get wet.
