rickco007
- Dec 11, 2014
- 13
Hi all,
I read on most of the installation manual of a pulsation damper that it is recommended to install it as close to the displacement pump as possible.
I wonder what will the impact if I install near a sensitive system where the flow need to be non turbulence? Will that help to damper the incoming flow and pressure?
Best regards
Rickco
Best regards
Rickco
