mechanver
- Jul 30, 2013
- 5
- 0
- 0
dear fellows,
I have problem with a multistage centrifugal pump known as VEB pump the problem is that from one month ago it was found that loud noise come from the rear bearing so pump was shut down and dis assembled to view what is wrong with it
there were bad deterioration in back bearing and mechanical seal damaged
we install new bearing and mechanical seal identical with its manual recommendations but the new bearing work only for 3 hours and then damaged this problem occurred 3 times and untl now i cant find where is the real problem with the pump despite the pump was install with high degree of alignment check and when stars no high vibration
i need your expert to help in this problem
