Hello, I was curious on centrifugal pump cavitation. If there is a discharge valve on the discharge section of the pump that is fully open, why does discharge pressure decrease and why can that cause cavitation in the pump. I understand that if the discharge valve was shut then discharge pressure increases but it stumps me as to why it can decrease when the discharge valve is open.
