Pump Selection
WissamH
28
Dear All,
I need to pump 21 L/s at 105 m of head into a water network. The pump I plan to purchase is going to be from KSB. Can you please help select a suitable pump based on the design values I mentioned?
Kind regards,
Sorry I cannot offer more! Is this pump working 24/7 or intermittent?
Check with KSB or other vendors (Sihi, Durco, Moret, Etc.). At least you have ways to improve the screening.
Good luck
Pierre
what are your rising main parameters? pipe dia, length and static head. 105m sounds quite high.
The pump you selected doesn't meet your criteria as 105m is above the curve - looks like a max of 102m. perhaps increase the diameter of your pipe, (or just a portion of pipe) and get the TDH down to about 85m you will find more pump options
pierreuck and swazimatt, thank you for your kind responses. I am going to switch to another vendor where I can find more options,
good idea, just ensure you supply all operating conditions, otherwise you will only end up confused again.
Artisi, Thank you for your comment.
what are the parameters you are trying to work with, pipe dia, length static height etc?
