Good day,
My Boss threw an idea at me which while sounds correct in theory, I'm not sure how accurate it is practically. We have 6 vertical pumps in parallel and there's a discharge gauge on each. We have no individual flowmeters, just a total flow of all 6 pumps from the header. My boss was suggesting to check the power required by the pump and use this value on the power curve to obtain a flow value and then plot this on the performance curve with the pressure value from the gauge. Is using the power to obtain a flow value accurate?
