Purge rate 1
Idontknowit
Chemical
Feb 12, 2008
23
Hi Folks,
Any tips/references on how to calculate purge rate for small scale test rig will be much appreciated(consists of receiver tank,high pressure reservoir,gas expander,test section,intermediate low tempereature pressure tank) ?
What are you purging (e.g., are you trying to get rid of air prior to introducing flamable gas, or trying to maintain a known atmosphere for maintenenace)? What kind of purge are you trying to do (e.g. a clearing purge has a different design than a dilution purge)?
David
Hi Zdas04
2 reasons for purging:
*Either the gas is to be replaced.(Flamable gas consisting from 80-90% of methane,5-10% CO2,2-5% N2)
*depressurise and dismantle parts of the test rig
It is clearing purge.
Chapter 7 of Chemical Process Safety: Fundamentals with applications by Crowl & Louvar (Prentice Hall) describes several purging procedures.
25362,
Can you please send me some link to review chapter 7 of this book?
25362,
I need to calculate purge rate, not look for purge procedures. If book which you recommended only describes purge procedures,then it is not what I needed,
Idontknowit, every procedure is exemplified with a calculation.
