ThereAre4Lights
Aerospace
I looking at bonding and grounding of aircraft components. This process includes surface cleaning to ensure good conductivity between contacting parts. My main sources are AC 21-99 and SAE ARP1870A. The two have directions on cleaning of aluminum surfaces and I am trying to reconcile them and make sure they are communicating the same processes.
My question is that in the AC it says:
"Apply a coating of petrolatum compound to bonding or grounding surface of aluminium structure and clean surface thoroughly, using stainless steel wire brush with pilot as shown in Figure 13–4. Wipe off the petrolatum compound with a clean dry cloth."
The SAE document does not mention the use of a lubrication and I cannot think of a reason for it. Does the petrolatum help remove material? Soften the surface? Allow the brush to move more smoothly across the surface? I am not sure. Does anyone know? I wonder how important it is and whether we are OK sanding without it.
Any info would be great.
