Hi everyone,
I am trying to figure out whether PWHT (Post Weld Heat Treatment) is required per code for non-pressure parts welded to pressure parts under the following conditions:
The material is P1 Gr.1 for both the pressure part and non-pressure parts. PWHT is not required for service.
1) The thickness of the pressure part is 1.75". The non-pressure part (clip) is 1" thick. The fillet throat thickness is 0.75".
2) The thickness of the pressure part is 1.75". The non-pressure part (clip) is 1.625" thick. The fillet throat thickness is 0.5".
I am confused because UW-40(f)(5) states "the thickness of the weld at the point of attachment when a non-pressure part is welded to a pressure part" is the nominal thickness as used in table UCS-56-1. My understanding is that PWHT is not required for either (1) or (2) because the weld thickness is not greater than 1.5".
On the other hand, note (b)(3)(c) to table UCS-56-1 states PWHT is not mandatory "for fillet welds with a throat thickness of 1/2 in. (13 mm) or less used for attaching non-pressure parts to pressure parts. When the thickness of the pressure part exceeds 1 1/4 in. (32 mm), preheat to a minimum temperature of 200°F (95°C) shall be applied prior to welding each pass". This tells me the weld in example (1) requires PWHT but the weld in example 2 is exempt from PWHT.
Thanks!
Thanks!
