cratechallenge1
New member
- Aug 23, 2021
- 11
Hello all,
Quick question: I've been reading the forums here for a few hours and I'm pretty sure I have my answer already but I'd like to confirm with the community to make sure I'm thinking about this in the correct manner.
On a tubular part, I have two cylindrical features that I'm trying to control the coaxiality of (relatively tight)--one is a simple locator feature (for assembly) and the other is the internal cylinder bore, with the central axis of the internal cylinder bore being the primary datum feature. I don't mind if the locator feature is slightly out of round (as long as it falls within the feature tolerance limits), I only want to make sure that the central axis of the locator is coaxial with the central axis of the internal cylinder bore.
I've been debating back and forth between using either total runout or position to control the locator with respect to the primary datum, but since I mainly care about the axes of the features lining up would it make the most sense to use position here?
For reference, this part is essentially a long tube so the manufacturing will be done on a lathe.
Thanks for your help!
-cc1
P.S. as a side note, how would an inspector get setup to measure the positional tolerance of this?
-cc1
