ASME SEC. IX QW-403.10 limits the material thicknes up to 1.1 times of the thickness welded for short circuit transfer when the material thickness is less than 13mm.
Does this limitation apply to short circuit+spray arc? I mean, what should be taken into account when a test plate is welded with short circuit for root pass and with spray arc for the fill and cap passes.
Thank You
Thank You
