I have heard that when an automobile system is converted from R-12 to R-134a that the charge should be 'lighter'. Say approximately 80% of the capacity of the O.E.M. R-12. Does this mean the cooling capacity of the system is now diminshed by 20% ?? I know that systems which are designed from scratch to use the R-134a refrigerant will have copper instead of aluminum in the condenser/evaporator coils and this is because of the improved thermal conductivity. So when the R-12 is swapped out for R-134a you are already handicapped by the aluminum components. What about the less dense charge? Does the converted system have a chance of reaching the same cooling capability as the original? If not, what compromise is considered 'reasonable' ?? Thanks in advance for any help from all........ Bill93XJ
