seymours2571
- Aug 17, 2001
- 236
Hello All,
I am trying to perform a modal analysis on a 3 piece bracket system with a cylindrical isolator. I have test data for both the axial spring rate and the radial spring rate.
The problem is: Even though I am using a cylindrical coordiant system, I cannot seem to simulate the radial spring movement correctly in Mechanica. The spring properties dialog box calls for Kxx, Kyy, and Kzz for the spring rates. There is no location to input a Krr (radial spring rate) even thought the spring is referencing a cylindrical coordinate system.
I can attempt to resolve the radial spring rate into two spring rate vectors (Kxx and Kyy), but I don't believe this will yield very accurate results.
Any help would be appreciated.
Thanks,
Steve
Thanks,
Steve
