Radiant Slab Tubing....Best way to Locate
bigmig
I was wondering if anyone has experience with a project where you had to locate the existing hydronic tubing in a
radiant slab. How did you do it?
I have to put some supports below said slab, and it would be ideal if we could do this with a micropile that can penetrate
between the tubes without ruining them.
Thanks in advance.
Turn on the flooring and use a thermal camera
If you don't have a thermal camera, I have been told that, with the heat on, wet the slab and the tube locations will dry fastest (revealing their location.
Are the tubes metal or plastic?
I have seen Cu ones located by putting an AC signal on them then tracing with a handheld probe.
Maybe a snake with a magnetic head.... like the guys use to map out leach lines.
