RAM output
RonnyRaygun1
Just started using RAM and am beginning to get to grips with it, but am at a loss as to how to get report output for single elements.
I just want the bending moments and shears for the beams at one level, and try as I might, I can't get what I need. No-one else in the office has much more experience of the software than me and so are unable to help.
Help would be fantastic!
In RAM Concrete Beam, the demand envelope is shown in the view/update dialog box for each beam line. For whatever reason there is no specific report that shows the bending and shear graphically. You can use the concrete analysis mode report - beam line force envelope if you are only interested in gravity loads, or you can use the concrete beam mode report - beam design to get critical forces at all stations along the beam.
