We use straps, load rated ones, for lifting all the time. But the ratchet is the thing that worries me about lifting. It just adds another thing to need regular inspection before use, only what would you look for (worn pawls, missing or sticky spring...). And would the winding of the strap tend to make it wear more quickly, or does the relatively tight wrap radius make the strap weaker (like a knot factor)?
That said, #3 son uses what is essentially a ratchet strap for slack line practice. Not sure how high he's gone (I think less than head high) with it.
Thank you everyone for replying. I have attached sketch of a hypothetical case. My question is more just in general: would you use a ratchet strap as the primary lifting support for overhead lifting? Instead of slings or wire rope or chain? Assume ideal conditions: safe WLL, lifting rarely, wear not being a problem, consequences of failure not severe.
From your answers already, it sounds like there are situations that people would allow ratchet straps to be used for lifting, since I was asked for more details. I thought I might just get a straight "No".
Buy certified load rated slings to use.
We used to use some ratchet straps to adjust an item but it was then pinned in place without long term load on the ratchets.
