Re-loading a part file
KhimaniMohiki
Automotive
May 14, 2013
134
Is there a way of re-loading an un-saved modified document without closing down CATIA and re-loading everything in session?
Khimani Mohiki
Design Engineer - Aston Martin
NX8.5
That's surprising, its something we would do regularly in NX. Is it possible with PLM integration (ENOVIA, Teamcenter etc)?
Khimani Mohiki
NX8.5
Warm Start??? Clear History??? (I don't understand what/why you want to do?)
Its quite commonplace on NX, when a group of designers are working on interfacing components you often want to re-load parts to see the latest saved version so you can design your part around it, without having to close down your whole session. Can you elaborate on what a warm start and clear history do?
Khimani Mohiki
NX8.5
Thanks for clarifying. Neither Warm Start or Clear History will help with updating the latest version.
SmartTeam has something that will help, but the part has to be saved (checked-in) to the vault first. SmartTeam shows a symbol in the tree when a loaded part is not the latest version, in which case you can use the REPLACE WITH SELECTED REVISION command to load (update) just that one part.
OK thanks for your help, hopefully we will get some PLM soon
Khimani Mohiki
NX8.5
You could try to unload the part and load it again....(right click on component(part)/components/unload)but I do not know if that helps though
It wont let me unload if the part has been modified, even if its just showing or hiding components and elements
Khimani Mohiki
NX8.5
