Re-naming Blocks 1
cve60069
84
I have a number of blocks that I would like to re-name and I cannot seem to find the correct method.
Any suggestions, please?
There is a command to do that...."rename", actually :)
I tried rename but I had to scroll through hundreds of blocks with similar names to find the block I want to keep.
Is it possible for me to select an individual block and rename it?
I guess the AutoCAD designers didn't think that someone might have hundreds of similarly named blocks :)
No, "rename" doesn't allow for picking a block, seems you would need a lisp routine that would prompt user to pick a block, retrieve the name, prompt user for new name, (preferably check the name wasn't already used), then feed this info to the "-rename" command.
How I've done that, is select the block that I want to rename, and "list" it. Then copyclip the block name from the text window.
When I go to "rename" I paste it to the top line. Saves scrolling.
Thanks ohiocad. I like the idea of a LISP routine to automate the process.
