Re-pointing Fiasco 1
XR250
5,556
Asked for some piers to be re-pointed due to cracks. Here is what the foundation contractor used...
In defense of the contractor, what did YOUR specs call for exactly?
I have a repointing detail on my drawings, walking the contractor through step by step. Even with that, it gets screwed up sometimes. Granted, most of the stuff I tell contractors to repoint is well over 100 years old, so extra caution is required....but this is a new sort of ignorance. Wow.
Makes sense for historic masonry where mortar compatibility is more of an issue.
Pointing is pretty universally known.
Now if hte spec had said "Fill cracks..." then they might have a better case, but don't think the word "point" is anywhere on that tube.
I could see that. I always refer to repointing when it comes to brick walls, but never say the word "crack" for this reason. When contractors see that there is a crack to be filled I assume they'll use anything from shaving cream to cool whip to apparently sidewalk silicone.
For me, it's repoint joints and replace cracked bricks. For especially bad vertical wall cracks that pass through joints and/or bricks, I'll also use stitch tie reinforcing. In a perfect world we wouldn't have be so nit-picky, but here we are.
Repointing (not tuckpointing) is a pretty universal term for replacing old mortar with new mortar. People do have an issue when trying to deal with smaller cracks that may go through the brick - sealant? mortar? leave it alone? No universal answer and as the comments above state, cracks that go all the way through the brick or wall may require some more attention.
Someone made a link to an IMI document above (good info). IMI also has a training certification for masons so that they have the right skills to repair historic masonry: https://imiweb.org/historic-masonry-preservation-certificate/. (Disclosure - I work for IMI). Designers can put this certification in their spec so that the craftworkers working on the restoration have the proper skills.
This is absolute gold. I just sent in a request for a list of masons in my area. Thanks, masonrygeek!
